That should work... awfully close to the "hot spot", but if you can get a longer one, and use a pipe bender to navigate away from the exhaust?Slow progress.
Got the right M8 studs in, looks good.
The right sized crush washers 12mm internal, 18mm external. So far Belmetric is a great place to get all this stuff from.
Got another drain to try. I think this one will work with some modding. A shorten and a bend will have it clearing so I can put a hose on. Eventually I will probably go to AN setup, but that can get pricey in this guessing game of trying to make it all fit and mock up.
Yeah I'm going to see if I can bend or cut/weld to get it further away. I like the first pipe I had I just don't like that it's slightly smaller than the outlet. Maybe it's not enough to worry about.That should work... awfully close to the "hot spot", but if you can get a longer one, and use a pipe bender to navigate away from the exhaust?
That should keep your rubber hose from melting...
Yeah, that is a pretty sharp angle... any time you can make things as free flowing as possible for both intake/exhaust it is advisable. But yes, you need to work with the space you have, and you want to leave SOME clearance because of heat. This is a tough one. The existing port already is at a pretty sharp angle, so at the very least you are not changing that if that is the route you have to go...I found this dump pipe. Looks like it would be much shallower and is 2.5” denco makes it. Too drastic of an angle?
At the end of the day you are still going to see a performance gain, and if you don't have neighbors too close you could test the difference with the 90 and just an open exhaust port!!
Do they make something like this for the flange? I originally had the flat exhaust flange on the back of my turbo but changed to one like this. No sure if it will help having the wastegate exit more freely?
I haven't finished my V2.0 exhaust to find out if it makes a difference in EGT yet
yesI'm guessing it won't work. Thats still for a CT26 correct?
