Odd that a simple fuel filter would cause that much trouble but.. if it had a bunch of material in it you could have accidentally shaken up the pieces and some went up into your pump.
Did you happen to eyeball the sight window on your carb?
Pretty classic ICS ground issue it seems to me.
Remember the ICS grounds (switches ) at the computer. Hearing it click means it works but again....the issue is not the ICS itself it the ground side
If it runs with the choke out that is probably it.
OK sorry I am not sure I understand. You are saying that the ground is provided at the computer which tells the solenoid when to energize and open. But if I hear it clicking, doesn't that prove the ground is OK? Otherwise with a bad ground the solenoid would not energize at all thus stopping fuel flow? It does run with the choke out when this happens.
When you say 'the issue is not the ICS itself it the ground side' you mean the computer in that it may be intermittently not grounding properly (switches on and off) when it needs to as to indicate the computer is maybe bad or the ground lead from the computer is intermittent.
Apologies for being slow here. I have like a week of these cruisers under my belt. Lots to learn. Thanks very much for the help.
OK got it. I'll try this and see if I get better results. No long term harmful side-effects to the solenoid running this way correct? Seems as though many folks do this so I would guess not. Are the computers available from Toyota any longer? Seem to be just PCB boards rather than actual computers. Like an electronic multi-switch of sorts. Thanks again for the help.
They aren't avail but some have had luck reflowing the lead on the circuit board or you can take it to an old radio/amp ect shop for them to do it.
I have my stock carb cooling fan board and I pulled it apart but couldn't see anything off. When I swapped it out tho w/ another I got from a guy here on mud I now have a working fan.
Do you have pixs of bad connections? Or are they that obvious?
Get a new carb from @Racer65 and you will be gold. Just did it. Runs like a sewing machine.
