1984 FJ60 Engine Sputtering, Bucking - FIXED!!!
AC, 1st set your normal idle to 650-700 rpms(wait till warmed up). Now turn on the AC, and adjust the screw so the with the AC on the idle is about 1000rpm's, turn AC off and it should go back to 650-700. with AC on idle will go from 650-1000 fairly often, depending on demand.. There is a selnoid that controlls the vacume to the AC idle up, if its gone bad it will cause the idle to stay higher than what the ac idle.is set at
Where is this screw for the ac idle up located exactly?? These are for idle up in blue and the red is idle speed with choke, correct?... where is the AC screw.... totally missing it.
Also, where is this solenoid for the ac idle up located? Thanks!
other side(front) of the carb below the sight glass window, only screw adjustment on the front of the carb.
pic borrowed from the internet(but its from mud)
The solenoid should hold vacuum on one port (the one at the tip)when there is no power on it. The other port should be a passthrough to the back little filter...air flows through them. When 12vdc is applied, there should be air flow across the two ports and no airflow between either port to the back little filter. So when the AC powers up, the manifold vacuum is applied to the ac idle up diaghragm.
The diaghragm should pull the linkage into itself if you put a mighty vac on it.
the original part is NLA but there are others(new Toyota from other models or Aisin's from amazon, $30-40) that will work in its place. If you desmog than I think the EGR uses the same part(or close)
Thanks! What is the easiest way to tell if it is bad? And are they still available??
Ok, I will do some more investigations... I adjusted the idle up to about 7-800 and 12-1400 on AC idle...sputtering seems to have gotten better. Still got a little sputter/skip at 7-800...any other thoughts that might help?
If the idle is jumping up when the AC is powered on, the solenoid and ac idle up diaghragm are working.
I have my idle @700 rpm. With AC idle up its @900. 12-1400 rpm is bit high i think you have poss vacuum leak/carb issue. What's fuel level at in fuel bowl?
I'll check fuel levels in the AM....carb is complete rebuild.... maybe vac leak... just re plumbed all vac lines and replaced a few vsv's ...engine seems to sputter below 750ish but is pretty decent at 750-800 and if I'm not at 12-1400 when ac is turned on... air is warm. Compressor is not getting enough rpm's at 900-1000? This is a brand new compressor with the 134 conversion kit... kind of scratching my head a bit.
....and if I'm not at 12-1400 when ac is turned on... air is warm. Compressor is not getting enough rpm's at 900-1000? This is a brand new compressor with the 134 conversion kit... kind of scratching my head a bit.
Might just need to adjust the setting on the AC amplifier.
Post#9 has a good method
Explain what the AC Amplifier does ?
Ok, that helped.
So, I have adjusted my engine idle to 700. Sounds good. I have also adjusted my AC idle to about 1000. I took a look at the amplifier Anita is at the lowest RPM. I verified that the compressor comes on and is spinning when button is pushed. Only problem is that the Air blows warm. The shop that did the R134 conversion said it was charged with 6oz oil and a pound and a half of Freon ...and no leaks... so now what? Are they B.Sh#**ing me? What am I missing?
