RSHARPfzj80
Appalachia Cruisers
What size spare you looking for??
I've got 6 37" MTR's still. I think you need all of them and the beadlocks they're on!
But for real Sam, if you only need one, I can make it happen. With or without a rim and high or low tread. Likely will bring the entire set to GSMTR for spares and to try to sell.
IH8MUD on Android
Don't really know at this point. I'd stopped trying to sell them since I thought about using them in Moab in October. We'll talk about it offline though. Either way, you'll have a spare tire after GSMTR.How much you looking to get for the set? I'll def take at least one on a rim for a spare. It would benefit you more to try to sell a set with the ones that have good tread tho. Since mine is just a spare it doesn't need much tread, just needs to hold air.
Sent from another Galaxy
No idea.
Ask Ted; he built his inner cage. Be VERY mindful of where your head "bobbles" when building an inner cage on a compact truck. I think he got used to the driver's side so he probly doesn't notice anymore, but my head didn't like riding in Ted's truck after he got that cage.Lol... I'd really love to know for a possible future build so let us know what you find.Best of luck!
-Daniel Kent
Dang, that is quick, heck you'll be done with that before I even get my valves adjusted... speaking of, does Mr.T have any secrets for cold valve adjustment? Everything I read says to adjust warm, but that requires a running motor....
Pretty sure it's gotta be warm. You can just run the engine for a bit to get it to temp and then adjust.
Oh yeah (to jynx): warm the truck up and adjust valves. It does not have to be running hot.. Driving it on the highway for 20 minutes will warm it up enough.
It will be hot though while you work on it.
Pretty sure what Jynx is saying here is that the motor has no way of heating [itself] up.~.....but that requires a running motor....
But Jynx, they are both right; I don't think you can get a proper adjustment without it being at operating temp. I'd think you should just adjust them cold to a little looser than spec, then redo it later once its back up and running.
Man, I've seen them so far out of adjustment that I was surprised they were still running. You just gotta get it good enough and then heat it up and get them correct.
Just don't adjust them tight. You can burn your valves pretty quick if they are hanging open.
Sam. Have you ordered your Longfields yet?
