- Thread starter
- #661
Got it!
Here is a quick shot of the garage
Got it!
kinda looks familar, walk in and back out.
my shop looks the same.
Hmm, you can actualy walk in there, I have to take a few things out before I can even touch my cruiser.
Nice set up. I do miss the tv and fridge.
Kevin,
I expected some live narration, maybe a nice English accent "in this area you see one of my favorite rattle cans", etc.
Nice weld table but I can't really see it...
What would you recommend for a big, vertical, but very very quiet compressor - if there is such a thing? Doesn't low noise have something to do with low RPM?
Gus
Isn't it a good idea to let EP fully cure (week +) before welding through it?used a self etching 2k epoxy primer in several coats. I'll clamp it in place and weld right through the primer tomorrow.
Awl_TEQ said:I'm not sure. Had not really thought about it. I guess I figured since I'm only "spot" welding it in places the rest of it will cure in due time. I suppose if it was cured fully the heat would do slightly less damage to the area around the weld thereby leaving better corrosion protection, which was the whole point of the excersize.
I don't think it will make a lot of difference either way. I was planning on using a wet rag on the backside to minimize the heat affected zone anyway. But I could be way off base, any body else have an opinion they'd like to share? I'm all ears...
