Hi! I was changing the burnt out bulbs in my instrument cluster. Before I started all the Gauges worked and both turn signals. When I put it back together the fuel gauge and the amp gauge are not responding and the turn signals are not blinking on the cluster but I can hear the audible blinking and the external blinkers are flashing. When I started I forgot to disconnect the battery and I got alittle arc when the amp connectors came close to metal. As to the amp gauge not sure I put the correct wire on the right pole. I put white wire with blue stripe to negative and plain white to positive. Also my stereo stopped working...help
