bmoonhajjar
GOLD Star
- Thread starter
- #61
It was totally roached. Came off in a bunch of crumbly pieces.Dash pad?
i could use the 22r carbs. also if you have the windshield catch handles, floor mat and tire carrier locking latchBased on that info, I hope mine works. Didn’t realize they went for that much. Mark, do you have any use for 22r carbs?
All of that has been sold.i could use the 22r carbs. also if you have the windshield catch handles, floor mat and tire carrier locking latch
thanks
I might have one of those.Dash pad?
Mark, let me know. It doesn't have to be mint. Cracks are good.I might have one of those.
Call me.Mark, let me know. It doesn't have to be mint. Cracks are good.
I have no idea. I would need to check.Would you happen to have the bracket that holds the brake hardline and brake soft line together towards the front please? Is circled in the attached picture. Thanks
Thanks! It would be attached to the frame with a bolt. I’ll need the bolt as well. Here’s a picture of it from a local mud member in my area. It will be next to the battery tray mount.I have no idea. I would need to check.
Yes, but I cannot get the set screw out.Headlight switch available?
Bummer. Thanks.Yes, but I cannot get the set screw out.
I will keep trying but might ruin switch if II need to drill it out.Bummer. Thanks.
Any luck please?
I looked but nothing thereThanks! It would be attached to the frame with a bolt. I’ll need the bolt as well. Here’s a picture of it from a local mud member in my area. It will be next to the battery tray mount.
??? On a ‘76?Do you have the 2 gas tank straps? Thanks.
There were none.Do you have the 2 gas tank straps? Thanks.
