Actually '75 also has the old style single diaphragm booster. Dual diaphragm fat booster started in '76.
Yup. I misread my source, SOR.
I have an 8/75 with drum and a single style booster, but am in the process of doing the disk swap. What does the dual diaphragm accomplish? I was just planning on removing the residual valve on my master and adding a proportioning valve, but am wondering now what the dual diaphragm is all about.
I have been looking for a booster for my '76 FJ40. What I've learned is that suddenly, in 2013, it is no longer possible to find readily available units that are rebuilt by the community at large, much less by the big remanufacturers. I have attempted therefore to revive this topic again, and to document, in one tidy place, what I've found out in the past 2 weeks looking for a '76 FJ40 Power Booster.
- Booster Dewey (repair place in Oregon Booster Dewey Power Brake Booster Exchange Inc.) cannot get diaphragms anymore either. He is done with the 76-80 rebuilds unless someone starts making the diaphrams again. He can do '71-'75. Might be an alternative if the bolt pattern is the same, though they are not dual diaphram(? fact check me here)
- There are a few remaining rebuilds out there, but they are around $400 and up at SOR and other sites. If you want original OEM, then you will have to pay.
Talked With Steve at Booster Dewey and they are no longer able to rebuild the boosters for the fj 60s and fj 62s 1980 to 1990 either; parts unobtainable
Lou
I believe @Racer65 is working on making all new ones, better than oem quality. Not rebuilds. Eta is tbd. Hth
Production is on track for October delivery. However, the booster is not intended for FJ60 or FJ62.
There are 3 Different Year Frames that the Brake Booster made a change:i found this at cruiserparts.net and i was wondering if anyone has tried it?
Disc brakes require more clamping power than drums. A dual diaphragm booster gives you more power assist without requiring a larger diameter shell.
I know quite a few people have converted to disc brakes but still retain the original single diaphragm booster. From what I know it still works.
www.powerbrakebooster.com
