For Sale 1972 FJ55 (HDT/auto swap)
Located in Ontario Canada.
I searched for months for a clean FJ55 to use as a basis for a HDT auto swap.
There is a lot of veneer trucks for sale, but i needed a solid unit to work with.
Word of mouth brought me to this one from PA. It is an excellent base to build from. solid frame. solid body, interior is acceptable.
Presently it has a HDT auto swap almost completed. so far, HDT auto installed with new hoses, water pump, timing belt, tensioner, BEB, shifter cable, 100 series exhaust dump, valve settings checked, front heater recored, rear heater tested and cleaned, pyro, water and oil gauges tastefully installed, HD engine and custom tranny mount, drive shafts with new Ujoints, recored rad with auto cooler installed, HD pusher fan, battery tray relocated, fuel filter housing, brake lines front and rear, vacuum line, fuel line return and inlet, air box and turbo lid, floor modified to allow for auto, interior heater lines, shift linkage modified, throttle linkage modified, wiring cleaned up, 3.70 diffs swapped in, 70 series rear axle modified and installed, rebuilt front and rear diffs complete, starter tested, alternator tested and refurbed, etc.
It has a previous owner installed Scout PS. custom made lines join the factory PS pump to the box.
The customer has changed his mind and is heading in a different direction.
All that is left to finish the swap is the exhaust, E/brake cable and handle, a bit of wiring and the shifter.
Once completed, this will be a very nice vehicle to drive.
This would make an excellent highway, back road or even daily driver vehicle with great acceleration, low highway RPMs, exceptional fuel mileage, comfortable ride.
Feel free to contact me at wayne@crushersrule.com for pics and discussion. i have the before refurb and present pics.
(Shiver) its that time of year again
Park the summer vehicles and dig out the "sacrifice to the rust Gods" winter beaters
as long as you take it for monthly drives to keep the engine running smoothly ...
what is the speed limit in that fair state?
Roughly 105 kms......
Like newer Cruiser derivatives...
Even the $$$$$$$ two part epoxy on my dearly departed 80 did not hold up to treatments here.
Speculated amongst the coating crowd that, if you care about it, don't drive it until we've had 12" of rain AFTER the last snow storm, because the residual chemicals.
That translates into NEVER driving a Pig.....although I've done a bang up job of ensuring against that, by my own doings.....
ih8rust much worse than ihanythingelse...... except celibacy.
..it will cost about $5K to finish the install.
cheers
Well, not my favorite color scheme for a 55, but for $5K I'll take it! :D Seriously, get this fawker driving and post up more photos for us.
Very nice truck but don't tease by not putting at least an idea of the price you are looking to sell it for...o_O
i have full reciepts for the base truck, the donor diesel 81 purchase, all the parts since to do the install, the hours.
there is $15K in labor and parts outstanding.
the customer wants the initial $11K for the base truck back.
$26K min.
the customer has over $35K into the build.
to finish the install will be roughly $5K if the buyer wants a running rig.
cheers.
