So I’ve got a 71 fj40 with sbc350. The oil pressure and water temp gauges aren’t working on it. How can I determine if it’s the gauges or the sensors on the motor itself. Also it has a silver speedo gauge that’s not correct for my year or is it?
Thanks I also have a painless harness does that make a difference? I didn’t do the install but bought it that way without the two gauges working. I’d love to get a Dakota setup but saving for that now so just want the stock gauges to work for the time beingHere's a thread with the knowledge you're looking for—> Stock gauges w/ SBC
What do the adapters look like. Theses are the ones on my engine. Does that mean they won’t work with the stock gauges as is?I would think the painless would be fine. I wonder if @Downey has those oil/water sender adapters in stock.
So basically I need Toyota units with adapters to fit my Chevy block? I think mine are the same as yours aren’t they? So it must be my gauges are bad?
That's what I did. I'd say our temp sensors look different, but I can't definitely say yours is wrong. I'll have to find a picture, but I want to say the Chevy sensors looked similar.So basically I need Toyota units with adapters to fit my Chevy block? I think mine are the same as yours aren’t they? So it must be my gauges are bad?
forum.ih8mud.com
forum.ih8mud.com
Not yet been super busy at work hopefully I’ll be able to mess with it soon. I may just change out the whole gauge cluster all together. But I’ll still have to determine if the sensors are GM or ToyotaYou're Killin me, you get it fixed up?
Not yet been super busy at work hopefully I’ll be able to mess with it soon. I may just change out the whole gauge cluster all together. But I’ll still have to determine if the sensors are GM or Toyota![]()
