- Thread starter
- #761
I have it pretty well adjusted.Then its probably similar to the clutch pedal height and freeplay adjustment at the mc. There needs to be slight freeplay between the master and pedal rod.
The issue is that as I apply brakes in succession, they get stiffer and brake height gets higher.
Something in the LRR cylinder is acting like a check valve, imo. This theory is supported by how difficult it is to bleed that cylinder. I have to screw the bleed valve out excessively to get fluid and then it is a geyser instead of a nice even flow.
I ordered a new cylinder from Kurt and a new LFR as well because why not. Once I install them I think we'll figure out what's really going on.
