Send it over to buckroseau, he can fix that roof no problem. did it bend the door frame? it does not look bent?
Excellent! I thought I was nuts (cause it took so long) when I welded a lip to my quarters, but it made them so much stronger!
Your project is looking great. Sorry about the tree, BTDT.
I'm just using a tape measure and taking into account how much the metal will shrink with each bend. I figured that out by trial and error. The metal does not move out of alignment once there is pressue on it however the metal does not stay still, it moves up or down depending on the dies. Here is a couple tips: make sure the metal and the dies are very clean. Use a liberal amount of a very low viscosity lubricant on the dies and/or metal. Once you make one bend (rib), clean the dies and the metal before you start another one. WD-40 worked pretty good for me and its fairly cheap.Miker, A couple of questions?
1. when you do the long bends for the bed, do you use a spacing jig to keep each bend consistent? If not, how are you measuring and as you start the pressing does the metal try to move? Or does it just stay on the line and just sink right into the piece as you press?
Several minutes because I'm using several jacks, I try to press them equally so it takes some time.2. how long doe it take to press one ridge?
I don't think the jacks are strained but the frame is definitely being strained. Sometimes scary strained.3. with the 3-20 ton jacks, would you say the metal creases easily or are the jacks strained?
Easier (because they were shorter) than the longer bed ribs. I don't know the formula for calculating the force required of a particular bend but after my experimenting, I would not be surprized to find out the length of the piece being formed is a square (like, power of 2).4. same question as #3, but with regards to the double rounded end pressing for the wheel wells. how hard are they to press.
On the shorter presses, do you use all three jacks? Or will my one 25 ton be enough to press say a 18-20" punch with curves at each end? What would happen if you heated the end curve just as you were pressing it? Would the metal just warp all to hell and become weak? I may just press some end pieces to use as fillers, those would be easier to do. I have a 52" brake/shear but your method looks much easier.
pressed the wrong way - the raised field around the 'TOYOTA' letters is pressed in instead of out. Is that what you mean?
