On color...I'm now leaning more towards the 416 Dune Beige. I've seen a lot of other 45's with this color and I like it. The reason I was not going to paint it this color was becasue it was so popular. It's becoming hard to make the final decision.
On the cab shelf and cage...after removing the rear cab shelf on mine and spending some time cleaning and derusting, it looks to be worse than originally thought. So, I've also removed the 4 seat belt support "L" brackets so I could check behind those. I will probably also remove the cab bolt plates and check under them. Then I plan to fab up new cab bolt support plates and integrate those into an area to also mount the cage.
Sheet metal...I'm gonig to have to replace some metal under the shelf as it was rusted much worse than originally thought.
Next I plan to lay out the cage and seats and determine if the stock tank will work. If not, I will either make a new one for under the seats or find or make one that will work under the bed.
X2 on my truck. There is some rust around the sheet metal X braces under my cab that will no doubt need the same treatment when I get to it. I will be building the cage to the point where it mounts to the top of the shelf and then the rest later after drive train. I'm gonna fit my drive train before removing and doing body work on my cab.
Also, I can do your fuel tank if we can colabarate on a design and keep the total cost to you at something you can live with. I'll be making one for myself anyway...
Kevin
