Where would the put the middle then? HmmmmI want to come!!!![]()
Possibly! The decision to go full mechanical is going to put me behind in the search for horsepower but I am trading reliability for it. I'll still be able to get to that 220-250 mark "I think". I think it should be a great setup in the end it will just take more time to get all the parts than I like. Pump is about 4 weeks out for instance. I'm not going to let it slow me down, I'll just table the engine mods and move on with the work. It will also mean I can't get it going before the snow gets deep here so with that in mind, I have oodles of time now. Up next is the dana 60 swap!!!! Ordered all of the parts yesterday.We should meet in the middle and drag race when you're ready.
This thing is gonna be sweet! Where are you in Montana?
That's surprising... when I ordered my turbo from Dark Side Development in the UK it showed up in about 5 days. To Minnesota. I was really impressed for $50.00 shipping and that fast.
Just food for thought, among many other benefits the idle torque control will be far superior with the original engine management system. Something that was very valuable for myself (especially when 4wheeling) when I used the AHU engine years back. It was also nice to be able to use the OBD2 for timing adjustments and diagnostics. Additionally there is a square wave generated from the ECU that would operate a standard tachometer.
If you really wanted to push the fuel system get an 11mm pump/loom/ECU from a wrecked automatic 1999-2003 ALH car. Or you can build a hybrid from the two.
I personally no longer have any interest in a fully mechanical injection pump after messing with both systems over the years.
For me it was an easy decision to go full mechanical. I'm adept at tuning mechanical diesels over electronic controlled. I guess you have to go where your bread is buttered. I'm old school I will admit but after all the investigation I have done I don't think there is going to be any issue. The pump I am having built as we speak is actually a 12mm pump, 20mm shaft with a 12mm cam plate. Governor springs, fuel pin and idle controls all adjustable. The ultimate reason for this decision is reliability. I understand that guys that are adept at reading scan tools and already possess chip burners and readers are doing great things. I'm not sure that is for me. Having the ability to make a custom chip or program for every modification would be fun but ultimately over kill. I would rather put my time into other areas of the truck.
Given also that mice here on my mountain love to chew wires. I already have one diesel truck down with wiring issues now because of them.
I liked the mechanical idea as well but struggled with it. Especially after taking one pump apart and seeing what was involved!
I'm on the other side of it, I've done engine calibration fro OEM's for my entire career. I can more than understand the learning curve when jumping into that realm!
Safe to say you are going with a waste-gated turbocharger setup? Have you made any decisions there?
You could keep the KKK03/KKK04 or GT15 that the engine shipped with and add a larger Holset on top of it.
If you are interested in talking to someone who has gone down this path and is (semi) local Matt Whitbread is a good guy to talk to. Here's his website: Whitbread Performance Innovations, LLC
-Mike
I had not considered compounds yet. I was looking at something like a HE221 or the similar size for larger single. .216 or .220 injectors are a given depending on the available boost. The 12mm pump will support more HP than I will be able to make on the stock bottom end. The next step for me (engine wise) is going to be a custom camshaft. That will give me a better idea of where I will end up.
Damn, that's a helluva setup.
Yeah, I was noticing that when I got it all together. I may rethink my doubler idea and just do the gear drive case swap and put the lower gears in it. That setup will be about 3" ( I think) shorter and do away with the chain drive transfer case.
How much longer is it than the Toyota setup from fan to output flange?
Snow melt off yet?
