- Thread starter
- #61
Hi Rosco
Actually I just double-checked in the FSM and the 29 I mentioned above is kPa at idle... I had misread this as 29psi (stupid mistake), which means that I have plenty of oil pressure as 29 kPa would equate to only 4 psi (that seems way too low, but anyway)… As I'm driving around and the motor has warmed up the oil pressure is around 40 psi. On startup it gets to around 70-80psi, which should be enough, so I don't think this is necessarily an issue now. One thing that worried me I guess is that before the rebuild the oil pressure always hovered around 29 psi, and then after with the run-in oil it was only about 15 psi. Now that it is back to the same pressure pre-rebuild I don't think this is such an issue.
*29psi is from a dash gauge
to many miles of confident motoring!
