13BT alternator vs 2LT vs 22R
Discussion in 'Diesel Tech / 24 volts' started by rutbeer, Aug 22, 2006.
  1. rutbeer
    rutbeer
    1,742
    4
    Jun 30, 2004
    Denver, CO
    I started thinking....and that's dangerous..... I have a 13B-T alternator that's 24volt, and I either need to swap a 12v unit with the vaccum pump, or swap to a different alt and use my mechanical vacuum pump. Well, looking at the parts diagrams, I think it's possible that you might be able to swap the stator and regulator out of another alt into the stock 13bt unit. According to the parts numbers, a 22R alt internals are the same (but in 12v). I can probably find one of these in a junkyard for $15, so it's worth a shot.
    The other thing I noticed, was that the 1985 pickup 2LT turbo diesel alt is a dead ringer for the one I have. The price isn't too terrible, so if the parts swap doesn't work, then I guess this is a fall back. Here's a link to the napa one....and one of them even shows the vacuum pump on there for right around $200.
    http://www.napaautoparts.com/master...8292&Description=Alternator+-+Remfd+-+Premium
  2. rutbeer
    rutbeer
    1,742
    4
    Jun 30, 2004
    Denver, CO
    Adding to my own post here....
    I called the authority on this kind of thing and he said it was the rotor, not the stator that must be changed. That and the regulator, but all the rest of the parts could remain.
    He also mentioned a swap that was interesting. He pulled a part from the shelf and said it should work, but that it had a larger vaccuum pump on it (better).
    It's an Isuzu NPR 4bd1 alt for a 3.9L engine.
    Isuzu number is 2-91276-300-0
    Hitachi number LR180503B or C
    Lester number 12235
    His was $265 w/vac pump...kind of steep, but if it's a high output and vac that never breaks, it might be worth it.
  3. rutbeer
    rutbeer
    1,742
    4
    Jun 30, 2004
    Denver, CO
  4. nickw
    nickw
    1,368
    1
    Jul 26, 2005
    Cranbrook BC
    What about a 12v alt/pump off a 3B?
  5. rutbeer
    rutbeer
    1,742
    4
    Jun 30, 2004
    Denver, CO
    Yeah, but I was looking for easy solutions in the states....not Canada.
    If there's a cheap and easy fix for those people that want to convert the 24v JDM engines over to US friendly 12V, then I'm interested. So far, it's not cheap now matter how you tackle it.
  6. OilHammer
    OilHammer
    280
    49
    Feb 4, 2011
    Denver, CO
    Holy crap! So my alternator just failed, and I was confronted with zero inventory out there on my original option. I did a google search, and clicked on a link....and it was ME from 2006! That's hilarious. It's like back to the future where I see myself doing something stupid. hahaha.
    Anyway, looks like the NPR option is about the only out there now. I'm going to order one and figure it out.
  7. OilHammer
    OilHammer
    280
    49
    Feb 4, 2011
    Denver, CO
    Made up a new bracket for the NPR alternator. I would have just modified the original, but it's really not ideal that way.
  8. cruiserpilot
    cruiserpilot
    6,059
    2,373
    May 15, 2005
    Ladysmith
    FYI, from experience, don't change just the rotor to convert to 12V. The stator also should be changed, I just went through this.
  9. OilHammer
    OilHammer
    280
    49
    Feb 4, 2011
    Denver, CO
    I didn't. I originally just went with a diesel pickup alternator, but it was a rebuilt one. Didn't last, and they don't really exist anymore short of 5 bones. I should have the NPR replacement bolted on tomorrow to try it out. Assuming I can get the hose connections sorted,
    That is.
