Wanted 13B Power Steering Pump Pulley
Tucson
I'm looking for a B series power steering pump pulley, with or without the pump. I prefer to buy just the pulley, but if you're looking to sell as a set please contact me
Thanks,
-Sean
Bump TTT
If anyone has anything please let me know, attached to a pump or not I'm flexible
I'm in the same boat. I just purchased a used pump & pulley; however, the seller forgot to mention he warped the pulley trying to remove it. Do you want the dimensions to track down an alternative?
I have a 60010 here and it does not seem to line up correctly
The pulley I'm looking for is 60050
my guess is that the divorced reservoir style is different. I'll have to see if the 3FE unit fits my bracket and lines up the pulleys
3F-E PULLEY will not work. Tried it myself and they are different enough to not allow the pulley to work. The center support section on the 3F-E pulley interferes with the pump mounting hardware. I tried spacing it a bit but then the belt becomes cock-eyed.
The pump will work when you remove the reservoir.
I've got one with a slight bend in it. It's not bent from removal but from a front end impact
