I’ve debated with myself about posting an update to this, because I have an overwhelming feeling of ambivalence about Augie’s Auto Body Shop and the work conducted. However, I think the importance of conveying information to other members who might find themselves in a similar situation and need body work done is paramount to my own feelings. Thus, I will try to write this without ‘airing all of my grievances’ and instead focus on the work and business. Everything below is on a scale of 1-10, with 10 being best.
Body Work = 7
Obviously the core support, DS fender, and DS fender apron incurred the brunt of damage when I hit the elk. Augie was able to pull the apron back
mostly straight, though it is still about 1/4-1/2” off; as a result, some things just don’t fit back exactly where they’re supposed to. The windshield washer reservoir in particular won’t bolt up all the way - it’s currently held in by 2 of the 4 bolts, because the holes for 2 just simply aren’t even close to being lined up. I provided an
undamaged, straight core support that
@knewstance and I pulled from a part out and I can see where Augie did some work to it so that he could bend it to the mangled apron instead of working the apron back completely straight. The hood and fender were replaced and the gap between them is uneven - about 1/2” wide below the windshield and 3/16” wide at the corner light. Part of me feels like this stuff could have been better and corners were cut, but another part of me feels happy that he could get it
close enough, considering the damage (cue the ambivalence train). From 10 feet away, it looks great, from 2 fee it looks Ok.
Paint = 9
This is where Augie’s work shines, literally and figuratively. Although insurance only covered painting the hood, DS fender, and grill filler panel, for a some extra bones out of my pocket, Augie resprayed the rest of the Cruiser to match. Like many of you, mine had noticeable oxidation from 20 years spent in the Southwest, so fresh paint on just the hood and fender would’ve likely looked more out of wack than I preferred. The paint is supposedly Italian and has a 5-year warranty, according to Augie. I’m very pleased with the paint job.
Other work = 3
If read back through this thread, you’ll see that I was very well aware before I took the Cruiser to Augie that additional parts would need to be replaced. For example, the A/C condenser, A/T cooler, A/C aux fan, fuse box, etc. The day I dropped the Cruiser off at Augie’s I told him that and also that I could get those parts quickly and/or install them myself if needed. He assured me that he would do everything - “the way this works is customers drop it off and we do everything - the A/C, electrical, everything - and then you pick it up like it’s new.” Let’s just say Augie’s definition of ‘everything’ and ‘like new’ are not the same as mine...
On the drive home from Augie’s after picking it up, I noticed the A/C wasn’t working at all, despite Augie telling me that he installed a new condenser, aux fan, replaced a couple of lines, and charged the system.
Problem #1: The aux fan relay and bracket were broken and instead of replacing it with a new assembly ($35 for relay and bracket from Toyota), the broken one was just wrapped in electrical tape and left dangling behind the bumper.
Problem #2: My 100 has dual A/C (front and rear). However, the condenser that Augie installed is for a 100 with
only front A/C. The bottom fitting on the drivers side of the condenser is substantially different between single and dual A/C. How does Augie resolve this foul up? Leave the wrong condenser in, jerry rig some bulls*** hose and adapter contraption, route it
under the front frame crossmember where it’s unprotected, bend the s*** out of hard lines to try to make this contraption fit together, and pinch two of the lines so that they crack and leak out all of the refrigerant.
Continued in next post because MUD has limit on # photos...
