100 series grille
I will try to get that his fall. Doing the entire R&P and valve cover gaskets this week, and need both catalytic converters. But this grille is something I really want. I might even sell my Martin Custom Shop guitar to get it,
Well, It's happening now, so thats up to you.
Searched but no lucky, anyone have a write up on how to wire up the 7" round light install with the headlight buckets? From what I can find it has to be an H4 but is there any issue with running an LED? Trying to avoid just cutting stuff up and winging it.
Specifically would like to run something with projector like this KC Lite 7" Gravity® LED Pro DOT Headlight - Driving Beam - Single - Universal / 07-18 Jeep JK - https://www.kchilites.com/gravity-led-pro-7-headlight-single-dot-compliant.html but it is an H13. This H4 would be fine too 7" Gravity® LED DOT Headlight - Driving Beam - Pair - Universal / 97-06 Jeep TJ - https://www.kchilites.com/gravity-led-7-headlight-dot-jeep-tj-97-06-pr-42361.html
TIA for any feedback ya'll
There are instructions on my website. I installed this kit on a late model 80 and it worked perfectly. I haven’t tried it on a 100 yet.
True Mods H6054 H4 LED Headlight Wiring Harness [Negative Switched Conversion] [Fused] Universal H4 Head Light Relay Harness Kit for 9003 H5054 H6054LL 6014 H6024 6052 6053 Subaru Toyota Jeep Headlamp
Thanks, Kelly! Saw the PDF showing splicing in the relay and thought there is no way it could be THAT easy. So that True Mods harness kept you from having to splice?
Yes, no splicing. Just connect the power and grounds, then plug it in. You still need an adapter from the H4 to the factory headlight plug. Let me know if that works on a 100 also.
I have several 100 series grille designs in stock, ready to build and ship. Also, 98-05 headlight housings for 7" round lights are available now. www.landcruisergrilles.com
I painted the 1 piece monster hex grille over the winter and finally installed it yesterday. Thank you @kelly saad for your fabrication and customer service.
Is the "Toyota" emblem on the front the one for the BJ7x? need to order one with the white letters.
EMBLEM, RADIATOR GRILLE 7531190K00​
is this the one?
is this the one?
Yes I think that’s the one. I will check the part number and let you know
