100 Series General Tech and Classifieds (12 Viewers)
This is bull****.
Another hour to get feet on and up on the truck square. Probably took another hour to tighten all the nuts since I had to do that with a hand tool.
My 3/8 snap on made the assembly much easier than by hand.
I could do a second one in 1/2 the time.
Love it. Looks awesome.
Plastic sunroof wind thing has to come off FYI. I gotta scrape the 3M tape off and I'm finished
Wow, that's nasty. I use either a heat gun or blow dryer to soften the glue before I try to remove it. I find more comes off leaving a little easier job. You might try a soft plastic scraper (like from the kitchen) and a little heat from a blow dryer to see if you can get a little more off. Then soak some strips of rags in WD40 and let it soak for a bit. That should soften the adhesive.
