100 Series General Tech and Classifieds (8 Viewers)
code said it was brakes. if i remember correctly probably ABS VSC.
OK - thanks.
I guess I'll start with the OBDII reading. After I pull the ATRAC fuse. Sounds like it would be any number of things. Or not. Trying to avoid the dealer throwing parts at it.
I have the paid and it works well.
Torque the free version.
I might pay for the other one. I need to play with it more but didn't really have the time. Should have the truck back this weekend. I hope 2 failed attempts on pickups.
I thought you already had it back.... That stinks!
Only if it is an active sensor in the system. ECM has to read it.
I had everything on my 2006 GX470 light up like yours. I had just bought it and thought maybe I had been taken by the seller.
Turned out to be a loose gas cap. Check that first.
JW
Thanks - just did. Wasn't loose but I removed and replaced it. Started the truck twice, coded out the same both times.
I like your thinking :idea: though.
Step one on the 90k completed today. Cutting it into two parts to ease the pain on the AMEX...
Spark Plugs, Fuel Filter, plus Labor, $320
All the rest sometime this month.
I have to rag a little here: You've completely disassembled/rebuilt/reassembled a 40, yet you have a labor charge from someone else replacing spark plugs and a fuel filter?
Just had to rib you a little.........:D
I know, I know. It's different when it's my daily driver. Just can't afford to be without it for any amount of time.
You are selling yourself short Andy!
http://www.youtube.com/watch?v=AWbnGviamC8
awesome!!! so we can expect pictures on Sat. evening/sunday?!
