100 Series General Tech and Classifieds
SUCK......sorry Andy
Atleast the house sold!!!
Yes. Drive it in 4. Peel the F out.
I'm on my mobile but I bet you could find the transmission ratios.
Post them up. I bet "4" is a bit of an overdrive.
I was actually just looking at this. I've attached the pic of the manual. It refers to using 4 for engine braking (which I've done before in the snow in other vehicles I've owned). If I've kept it in 4 would it try to slow the car instead of coasting?
I will look into the ratios. I believe it is a 7 speed transmission, but I'm guessing some of those are overdrive gears.
A750F first 3.520 second 2.042 third 1.400 fourth 1.000 fifth 0.716
So 4th is your "drive" gear.
Strongest gear. No overdrive.
OD is 100% not needed for anything but marginal fuel mileage gains.
Try it.
I drive mine from TX to Moab and back in Drive.
Hoping for good news Bomar......some bad vibes in here right now.....stinks.
About to go in for my 90k (10k miles too late) maintenance, and want to do as much as possible without going overboard. I plan on driving the truck until it dies, so I want to make sure I maintain it at an above average clip.
With that in mind, plan for this round is:
AT A MINIMUM
Timing Belt
Water Pump
Thermostat and coolant flush
LEANING ALSO TOWARDS
Serpentine Belt and Tensioner
Tensioner Pulleys
Idler Pulleys
Fuel Filter
OTHER OPTIONS
Camshaft Seals
Crankshaft Seals
Power Steering Flush
Brake Flush
Spark Plugs
O2 Sensors
Any thoughts on any of the above? I know a couple of you guys have recently done the 90k, interested to know exactly what you had done.
AT A MINIMUM
Timing Belt
Water Pump
Tensioner Pulleys
Idler Pulleys
Fuel Filter
OTHER OPTIONS
Camshaft Seals
Crankshaft Seals
Brake Flush
Spark Plugs
O2 Sensors
Why fix camshaft, crankshaft seals, o2 sensor till they fail? They are not maintenance items. The flushing of fluids, I am not the biggest fan.
Thanks Chris, and I agree on the seals and fluid flushes, just had seen others include them.
Have Jacque checking on all of the above for me.
did my 90k at 150k. Did timing belt, water pump, coolant, and serpentine belt. Labor was $330.
That's pretty close to what they quoted me for just those items. Service manager said changing the three idlers and two pulleys added significant time.
I'm gonna check with another dealer and an Indy shop as well.
Sent from my iPhone using IH8MUD
of all those things don't touch 02 sensors....they take 5 minutes unless you have rust and can easily be done with
1. code reader for which of the 4
2. I think a 10mm (at a really awkward position)
3. a beer
I read alot when I threw a code for left bank sensor.....some trucks go 200k and some go50k before needing one.
I'd look at parts from Sam at Lowe Toyota. Yeah shop won't insure them but it's OEM parts.....
Shush why are you getting out of the truck?
https://forum.ih8mud.com/uzj100-lx470/730584-99-im-2-lift-mississippi.html
being reassigned to a new position soon that will either require alot of travel or commuting an hour to another armory.
I hate to sell it, but we don't have the funds for a gas saver and the 100.
If this new job works out I will probably look for another one or a 40 in a year or so but for now we need the fuel mileage more than what I WANT to drive. I tried to convince myself to keep it but after working the fuel for a year on 30 mpg verse 13 it was painfully obvious.
If ya'll know of anyone point them towards the ad. It SHOULD have everything answered but if not pm or email me.
I struggled with price as they are all over the place and in various forms of factory to heavily modded with TB done or not so I'll let it sit a week and then test the craigslist cespool.
hope your rig is good to go soon.
I hate it b/c I don't have freed up cash to buy it or I would. I can't sell my 62 too attached.
Hell I emailed Summit Transportation and they are picking up my truck tomorrow and I will have it Fri or Sat. Now I can still break down the 62 and put diffs in. I am super duper happy.
