What will happen if the ohms are wrong for what speaker I chose?
mayan prophecy will come true!
Thanks for the link. I remember your comments about ohms and I used Crutchfield. I should have just ordered one. Looks like a PITA.
Can I just remove the bottom and get to the speakers ?
The bass is roasted.
Only your foam is roasted. If you're so inclined, the factory ones are, generally, repairable. http://www.simplyspeakers.com/The bass is roasted. It rattles anytime bass goes through it.
I ordered new ones. It was only $100 for both.
Kenwood KFC-1662S 6-1/2" 3-way car speakers — also fit 6-3/4" openings - Features & Specs at Crutchfield.com
4 ohm
As much as you refer to food, i completely had to re-read this the correct way a second time.
I've been nosing around. Few on CL in the surrounding states in the +/- $10K range.......Be patient. One will pop up (Let everyone know the exact specs - or range of specs - you'd consider)CLC, let's start scouring again for hunnerds. I'm beginning to lean that direction.... 10k-14k
after the sale of both sig rigs.
This '99 has less miles than my '03 (hard to tell, but it looks like it's got a rear locker):
