- Joined
- Dec 2, 2014
- Threads
- 17
- Messages
- 4,004
Landcruiserphil This set up gives you 2.75" more travel, which doesn't sound huge, but compared to stock I believe it is close to 30 percent more wheel travel. King Shocks Compression Adjuster « King Off-Road Racing Shocks : kingshocks.com here is a link to King Shocks web site where they can better explain the external compression adjuster. It is a very neat set up, and we have used them with a lot of positive feedback.
Yes, but nearly 2/3 of that additional travel appears to be on the "wrong side" of the travel (compression)
Just by dragging a jack and a tape measure out to my driveway, I can see that:
Factory UCA & Shocks = ~22.75" fender to center of hub at full droop.
SPC UCA & OME shocks = 23.5" fender to center of hub at full droop.
So I'm seeing ~0.75" of additional travel from aftermarket UCAs & Shocks. Maybe I could get a little more by swapping to slightly longer shocks.
Your LCAs certainly look beefier that the factory units, and I am somewhat interested.
My concerns are:
I assume that the optional bump stops are required to gain this additional up travel?
By simply raising the "resting point" of the frontend (by cranking on the torsion bars), I gain upward travel and lose downward travel. I'm most interested in adding/recovering downward travel lost by raising the frontend.
By increasing up travel, I lose clearance (above and beyond an OEM suspension with no lift) for larger tires.
The guesstimated cost to gain 0-0.25 of an inch of droop is kinda hard to justify.
While I wish that Toyota had originally designed the IFS of the UZJ100 as a coil over, I'm hesitant to convert to a coilover just for the sake of changing the format of the spring.
