ethanol content?
I experienced the same thing last year. I got a brand new OEM cap and a new fuel filter and have had zero issues since at either high altitude (Imogene 6 times, Mosquito 4 times, Argentine 2 times...all over 13k) or in high temps (60 consecutive days at 100+ this year in Texas).
Ethanol free gives me much better mpg and responsiveness. Sure wish we had it around here. Instead, I only seem to find it in Silverton.
You are correct.um, I could be wrong but fuel lines are on the driver's side.
2006 LC100 with the vapor lock and/or engine shut-off in high heat and/or gas smell not inside truck but noticeable once parked in garage. Has happened 4 times to me over 5 years. I still have the issue after replacing gas cap and replacing fuel pump. Next up is replacing the fuel filter (after 230k miles probably time anyway) then the charcoal vapor canister which will be $615 for my rig. Headed to HIHX in July...hopefully the event will still happen...and really don't want to deal with this issue any longer. I will look for ethanol free fuel while up there too. Also, according to the Toyota TSB I saw posted on this thread way back, my VIN# was produced before the production change effective VIN so even though I have had no codes thrown directly related, it appears that my vapor canister is the "bad" one.
Okay, I have a 2005, guessing same rear canister, replaced it for half the cost,OEM toyota, takes 15 min to do...long story short, still boiled at alt, my belief is it is the ethenol. There is non ethanol gas available in Silverton....either way don't fill up past 3/4 and you should be ok.2006 LC100 with the vapor lock and/or engine shut-off in high heat and/or gas smell not inside truck but noticeable once parked in garage. Has happened 4 times to me over 5 years. I still have the issue after replacing gas cap and replacing fuel pump. Next up is replacing the fuel filter (after 230k miles probably time anyway) then the charcoal vapor canister which will be $615 for my rig. Headed to HIHX in July...hopefully the event will still happen...and really don't want to deal with this issue any longer. I will look for ethanol free fuel while up there too. Also, according to the Toyota TSB I saw posted on this thread way back, my VIN# was produced before the production change effective VIN so even though I have had no codes thrown directly related, it appears that my vapor canister is the "bad" one.
Sorry, I should have been more clear.....my best guess is that no matter what you do, ethenol is the culprit....plenty of discussion on this.Isn't it also the 06-07 that seems to be the worst offender for this issue? The 3/4 tank solution seems to solve the issue for most people. This isn't an issue with HIH because a high mileage trail day is less than 50 miles.
I am struggling STILL on my end after hitting trails first time this last week. I will say it seems to take longer to vent but it still happened, one day was bad you could hear the "boil" happening in the tank.Yes I rebuilt my charcoal canister and my MPG went from 12 to 15 immediately and no more gas smell after normal driving. Worst part was the hoses, 3 of my MPG were just being evaporated into the air. Rebuild here:
Did not solve my problem totally. Went offroading above 10k ft and had my gas tank boil again. This time, though, fuel started coming out of my gas cap. I replaced it with a new OEM one after that. By fixing the leaks in my charcoal can I just moved the leaks elsewhere.
Hopefully will be wheeling again above 10k feet this weekend and hopefully no more fuel boiling! Doesn't boil in town only at high elevation. Hopefully new gas cap = maintain pressure in tank = no more boiling.
Yes, sure. Go ahead and blame ethanol when there are literally hoses falling apart and old seals leaking vapors.
Yeah I noticed your comments and others on that, it is an intriguing idea to wrap that line. I just never overheat per my thermostat and even reading via bleudriver app/OBD tool while driving. Plus how michnfuel really retuns to.the tank in these thing with how they burn fuel LOL!?!? I think it's an exhaust temperature thing. I have a feeling we all have more pinholes in our exhaust systems than we think on 17+ year old truck that have been running trails and everything else.Yeah it is annoying as heck. I am even considering a fuel cooler usually used on diesel vehicles like this one: https://www.amazon.com/gp/product/B07CZ5419P/?tag=ihco-20 plumbed into the return line with an electric fan.
The return fuel line also goes right along the top rear of the engine before it starts going under the car. I plan to add shielding to that line and possible the fuel rails themselves during any future intake manifold area maintenance. The fuel just has so many opportunities to pick up heat on the way back to the tank so my goal is to minimize as many as possible.
Wow! That is quite the list! In addition to the items I replaced and plan on replacing as I mentioned in my recent post, I also had both catalytic converters replaced in 2014. Now that was expensive...used OEM replacements. I am hopeful the $625 vapor charcoal canister I just ordered will at least help with the fuel smell on a hot day driving around town. I decided to go with the new canister rather than refill since the canister for my year also includes the valves so rather than piecemeal it just yank the whole thing and replace.I am struggling STILL on my end after hitting trails first time this last week. I will say it seems to take longer to vent but it still happened, one day was bad you could hear the "boil" happening in the tank.
So far I have replaced (I think in the order over the past year and looking at this list I'm half embarrassed ive put this much time/energy/money with the problem still there!!):
Charcoal canister
Vsv valve
ECT
Fuel tank, camp, filler neck
Fuel pump
passenger side catalytic converter
All 4 O2 sensors
Water pump/timing belt (unrelated I think but it was due nonetheless)
Fuel filter
I did have evap hoses tested at one point in there too and they were allegedly ok as well.
So my only next stop is a new driver's side cat,l or muffler and overall exhaust system inspection for any pinholes and then maybe going down heat shield route. But I have a feeling hear shield is a band aid for something being hotter than it should be in the first place.
The maddening part is the car runs like a top otherwise, I get decent mpg considering the vehicle, lift and running 33s, engine doesnt leak/burn a drop of full synthetic at nearly 198k miles. Really wish I could figure this out!!!
