Parting Out 100 & 105 series parts load! Boise, Idaho (7 Viewers)
SNLC
OCD
Supporting Vendor
Boise - Idaho
Website
www.snlandcruisers.com
  1. 100 Series
PLEASE READ the below listing of parts we have for sale. If it isn’t listed, I don’t have it so if you ask that means you didn’t read what I have listed for sale.
Need to move/unload a fairly big pile of parts from an abandoned 105 build. Project was canceled which is why we need to sell these parts.
To start here is a link to a complete listing of what we had.
Engine, trans, tcase and related parts are all gone. Axle housings are gone as well.
Cheers
All parts are new OEM unless otherwise stated.
58804-60110 Panel shifter (for manual trans) : $125
47201-60720 ADVIOS brake master cylinder: $125
44610-6A060 ADVIOS brake booster: $125
16470-66030 radiator overflow bottle assy: $50
16400-66131 radiator assy: $350
84013-60010 panel sub assy: $75
84012-60031 control panel: $250
87910-60801-C0 mirror assy: $100
87940-60840-C0 mirror assy: $100
55404-60120-C0 panel sub assy: $25
55223-60232 firewall insulator pad: $100
17700-66182 Air cleaner assy: $300
There is the first listing, feel free to make offers.
Cheers
Wiring parts that are not easy to come by (unobtanium even!), we basically have complete new harnesses for a FZJ105 in LHD. We also have a used one as well. Some of these parts may be the same in a USA spec UZJ100, up to you to figure that out.
82733-60031 block cowl: $125
82620-60010 block assy fusible: $25
82221-60050 wire oil press: $25
82141-60312 wire instrument: $30
82136-60743 wire dash/cowl: $500
82620-60030 fuse block: $20
82720-60070 fuse block: $125
82112-60245 wire engine #2: $500
FZJ105 Middle East spec complete USED vehicle wiring harnesses: $200
Cheers
37140-60500 front driveline (cross reference shows it suits any 100/105): $300
37110-6A620 rear driveline (should fit any 100/105-series): $300
41101-60091 Front 8" diff 3rd member housing non-Elocker (80/70-series), aka carrier: $250
41301-60080 Rear 9.5" diff case (this is your bare diff carrier that you bolt your ring gear to: $150
41311-60060 Same as above but for an 8" HP front diff: $150
41101-60180 Rear 9.5" 3rd member carrier, same as above but for a rear axle, non-Elocker: $250
55107-60160 Support Assy. clutch, (manual trans swap part!): $50
31301-60220 Pedal, clutch: $35
47110-66060 Support Assy. brake (Manual trans brake pedal and support assembly): $125
Cheers
curious if you have passenger front turn signal assembly, and a grey front bottom seat cushion?
Not a vehicle part out here so, nope.
Cheers
Any engine/skid plates/covers?? OEM steel cover w/oil filter cover, and plastic cover w/oil drain cover? (My steel one is crusty, and plastic one has cracks)
Please read the thread.
What I listed is 90% of what we have and we never had any body parts or 2uz parts.
Cheers
75744-60010-H2 exterior side trim: Full set for $150
75743-60010-H2 exterior side trim "
75612-60120-H2 exterior side trim "
75611-60120-H2 exterior side trim "
75731-60120-H2 exterior side trim "
75732-60120-H2 exterior side trim "
75652-60170-H2 exterior side trim "
75651-60180-H2 exterior side trim "
75741-60160-H2 exterior side trim "
75742-60160-H2 exterior side trim Full set for $150
SOLD!
Cheers
Would you have engine bay fuse box cover?
