1 PZ diesel question
canadian bum
Red Deer, Alberta
Is the bell housing pattern the same as any toyota pickup trucks, say like a V6 with a 5 speed?
the bellhousing bolt pattern is the same as the 1HZ but is a different length...
i think that is the case, it sure looked the same...
I'm trying to find out if it is the same as any gasser trucks here in canada with a 5 speed.
Might as well ask if the 3B is the same as any 5 speed tranny's to for bellhousing bolt pattern.
Im pretty sure they are the same Wayne. The gearbox stays in the same spot and an extension is used so the fan can reach the radiator.
1PZ to 1HZ= easiest conversion in the world:D
Edit: No they are not ,the 1PZ takes the little R151
how about gas tranny's are the interchangable?
Only the H,2H,12HT diesels can interchange with the gasser tranny.
Okay thanks
G&S have a 1PZ block and a tranny transfer combo that (I think) came off an other 1PZ.
What does the HZ use for a tranny?
The 1 HZ pre 98 in oz used a H55f in the HZJ75 .
Okay thanks.
