I swapped in a 78 2F into my 74 FJ40 and am having issues with getting it dialed in. Specs- 78 2F, w/ tri Y header, non-USA dizzy, pertronix w/ flamethrower coil, new NGK spark plugs gapped to .41, rebuilt 74 cali carb w/ vac advance port (emmision vac tubes blocked off), valves have been adjusted, and it has 20inches of steady manifold vaccuum. Compression (warm) across the cylinders is 140/130/120/120/120. New head and manifold gaskets. I have set the timing to 7 degrees BTDC and 15 degrees BTDC and no matter what I have a miss @ >2000 rpm under load (mostly in 2nd on the SM420). I am going to pick up new cap, rotor, and plug wires tomorrow, but was wondering if anybody has any ideas as to what is causing the miss? When I rebuilt the carb I followed the main and slow jet sizes specified in Ed Cooks write up in the tech section except for the primary slow jet, it is 0.60 rather than the specified 0.50. The exhaust smells like it is running a little rich also. Any help would be greatly appreciated. Getting tired of it sitting in the grage and not being able to drive it.
-Brian
-Brian
