Hello folks, how's it going...I actaully just had a few questions regarding some drivline vibes I am now getting with my newly installed 6" springs. Before I purchased the springs, I actually thought that my cruiser already had the full Slee Suspension already installed into the cruiser(the guy I bought the 80 from had told me that it had every Slee's Suspension part installed-which it does, execpt for the rear upper control arms......needless to say I am not that happy with this.....)I just recently discovered after the 6" springs install that I have some really bad drivetrain vibes coming at only approx. 20 miles an hour. Before and after approx. 20 mph it drives smooth...The front drivshaft is a double cardon + I have the slee front control arms, so I doubt the front driveshaft is causing any bad vibes.. So I am pretty sure that the rear driveshaft is causing the bad vibes since I have NO upper rear control arms, NO double cardon rear driveshaft... Not having these parts would be enough to cause my cruiser to have these bad vibes at 20 mph, right???? The cruiser starts to shake at this speed pretty violently.....
Oh yea, knowing that I have to get these rear upper control arms to fix this problem, how do you adjust the arms.. Do you have to adjust them with them installed, or before you bolt them on to the rear differential? Typically when you guys install these 6" springs and the rear upper control arms, do you guys adjust the arms to be longer or shorter to fix the pinion angle??------thus eliminating driveshaft vibes...)
