well, today i picked up my second re-built PS pump from the local napa store, and out it in. after i filled up with fluid, i cranked the wheel, and then turned the engine on.
fluid came POURING out fron the front of the pump, where the long bolt holds the resi on.
so, off came the pump, and i called the parts store, and explained my problem. while i rode my bike over, he removed the bolt from the pump i had JUST returned, and i also took along some o-rings.
back home, i pulled out the bolt, and saw that the little o-ring on the bolt was all f**cked up, so i decided to put the bolt from the returned pump back it.
But they are different lengths. so i kept trying combos of o-rings, and even flat washers like used on a/c units, but whenever i put the pump back in operation, fluid POURS out. the last time, it seemed to be coming from inder the pump. so out came the pump AGAIN, and i tightened all six of the 14mm bolt head.
pump goes back in, SAME thing.
so i called the store, and they said that they will have another pump for me Monday, and THIS one, they claim, is an actual factory toyota pump ( re-buiit) rather than some no-name.
my problem, other than having no vehicle till at least monday afternoon, is should i even try anything but a new oem???Cruiser parts has a brand new, with a resi, for about 350 bucks. i would have to pay overnight frt.
i dont know. i really cannot figure out were this stream of fluid wwas coming rom. all the hoses were right. and i dont mean a drip-drip, but a steady stream.
it seems awfully odd that i cannot get a pump that funtions correctly. and this time, i didnt even get a chance to take it on the road, to see if it worked!!!!
im running out of time, patience, and i dont feel like spending almost 400 bucks. the auto parts store has been very acommidating.
what should i do????
