60wag said:Gear oil won't keep the "planetaries" (birfields) lubed properly. I'll drip out everywhere.
cahilc said:Hmmm, debateable point.
Grease will activate only under extreme pressure and heat. Birf's get neither, IMHO. I'd rather have my birf's swimming in gear oil.
Everybody is cookbooking this answer and nobody is thinking.
The gear oil hasn't leaked out yet, I'll keep you posted.
cruiseroutfit said:Where in the "cookbook" are planetaries???
cruiseroutfit said:Sweet, run it in your front wheel bearings and hubs too... Eventually it WILL leak past the felt & rubber seal. Toyota engineers did not design them to stop viscous lube...
nuclearlemon said:oil is actually better for heat than grease, but, as mentioned, the felts weren't designed for oil. many full floater rears run oil all the way out. as for that little plug on the top of the knuckle housing...it's useless for greasing birfs. only way to do that is to pull it all apart.
60wag said:So there isn't oil dripping out the free hub knob? There aren't any seals in there are there? I'm really surprized the rubber wipers on the knuckle ball aren't leaking since its two pieces with a joint in the middle. With the amount of grease theat my knuckles managed to move out of the seals, I'm really surprised you aren't looking at an oily mess. Maybe it'll take a couple hundred miles to loosen up bit.
dd113 said:SHould work out just fine if not driven or wheeled a bunch. Drive a 15oo mile ride and plan on all new knuckle parts.
cahilc said:Plan on changing the fluid in the knuckles twice maybe three times a year. Pull it out throught the top plug and refill. Same technique as for a diff without drain plug.
As far as messier ... would be the same mess as replacing a differential gear. Viscious fluid is a lot more manageable than piles of sticky grease. IMHO.
Plus, I was real careful on the wiper reassembly and polished the wiper contact area carefully.
On first fill, we let it sit over night without a single drip.
cahilc said:...As far as messier ... would be the same mess as replacing a differential gear. Viscious fluid is a lot more manageable than piles of sticky grease. IMHO....
