- Thread starter
- #21
If it doesn't work out I have a sponsored rebuild from my mechanic.
Planning on changing the planetary fluids on the same schedule as my diff's. Every 15k. Takes about 5 minutes per side. I hit it with vacuum throught the top plug, pull out whatever I can and refill.
I will admit, grease is definitely the easier approach for maintenance. However, there are plenty of solid front axles running around with gear oil in their planetaries.
Cheers,
Cahil
P.S. Which leads me to the idea of machining a matching drain plug opposite the fill plug the next time I'm in there ...
Cheers,
Cahil
