I went to get in my '99 this morning and when it cranked up, I noticed a distinct misfire (it ran fine the last time it was driven) It will idle, and drive, but at least one cylinder is not firing. Seems worse at low rpm's, and smoother (but still obviously misifiring) at higher rpms. The check engine light came on and I got it read at Autozone; it has 2 codes--a general engine misfire and a misfire on #8 cylinder.
Without going through a parts swap, here's what I have deduced: Either a coil or injector has gone bad, possibly on #8. (I have seen on other model vehicles the check engine light point to a specific cylinder and that not be teh one broken). Can I test these with a multimeter? Do you any of you have the resistance readings that they should be? Or any other ideas that might be wrong?
