my new 80 had been getting repeatably poor mileage in the 12-13 range, changed the fluid in the diffs and transfer with Chevron Delo, only the front diff looked bad the others were dark but you could still see light through the drain stream, the front however was very thick and black ran out of the drain slowly, I assume contaminated with Molly grease as I also have some oil coming out of the knuckle seals
I did this about mid tank and that tankful got 14, filled up last night and the first full tank on new diff fluid got just under 15
a nice improvement not sure if Delo has any mileage properties like synthetics do, I think this is just a case of the old fluid being contaminated
after the birf repack next week I will change the front again. Also going to put M1 of the proper weight in the transfer (Delo is not proper spec for X-fer)
