tom warner
t-bone
thanks, it might melt? not good. this is a lot of tedious work to melt down afterward, thanks so much,
I can’t say for certain on that product, but the first time I insulted the brass pipes going to my rear heater I used pipe insulation from Home Depot… it did melt very quickly.thanks, it might melt? not good. this is a lot of tedious work to melt down afterward, thanks so much,
That’s a good point, something some of the mainland buyers might need to be aware of. But since I don’t have a rear heater, that insulation is only used on the two short segments from firewall to heater box, so will be easy to monitor its condition. Not sure it really applies all that much to me since the likelihood of my heater ever being used here in Hawaii is very unlikely.I just checked out the product you’ve linked. I has the working temperature listed as -40 to 176* F. Before you have it all together, I’d confirm it’s not going to melt when the brass pipes surpass 212’.
I’d suggest Armscell or similar high temperature pipe insulation instead.
LolI do have a twin sister, her name is Jess and is 3 minutes older than me. She is single and is even more into Land Cruisers than me.
But…she just entered the convent to become a nun because she said she couldn’t find a guy that loved owning multiple Land Cruisers and her excellent cooking/baking skills.
Thanks, I have that exact steering wheel cover. That’s kind of why I wasn’t too concerned about the wheel, so will probably install that this weekend. It looks like it takes a long time to sew up though.GREAT JOB! However, if the steering wheel imperfections bother ya, just slap one of these on there.
View attachment 3554645..View attachment 3554644
Yep, it's a pretty easy install, just takes time and patience. I installed mine with the wheel attached. Maybe get you a Velcro strip to be able to lock the stitching at a point if you need to take a break....One nanner job with your talent.Thanks, I have that exact steering wheel cover. That’s kind of why I wasn’t too concerned about the wheel, so will probably install that this weekend. It looks like it takes a long time to sew up though.
Did you install that one? Is it easier to do with the steering wheel attached or better off the vehicle?
Thanks for that post link, that will be helpful when I sew mine up.Yep, it's a pretty easy install, just takes time and patience. I installed mine with the wheel attached. Maybe get you a Velcro strip to be able to lock the stitching at a point if you need to take a break....One nanner job with your talent.
See post #1837 < click here >
I get wanting every last bit of protection you can get.One addition we added was something I had never seen before, so it might be a first. If it is, then i suppose it could be called the Aloha Jen spare tire brake light. The inspiration for this came from an article I was reading about how most rear end traffic accidents happen because the person behind didn’t see the person in from stop. This prompted the 1995 US safety mandate for all new cars to have a third upper brake light.
This got me thinking about my Fj40. The running/brake taillights sit pretty low, and with the larger 33” spare tire that could potentially obscure some of the left twilight…the idea for the Aloha Jen spare tire brake light was born (as far as I know. Apologies if this is already someone else’s brilliant idea).
It’s very simple, I got a new OEM hub cap with the center cut out for the front hubs. Then found a round brake light that fit snugly into the opening. The brake light also has kind of a retro vibe to it as well.
Then some tabs were folded out from the hub caps inner lip that lined up the the brake lights bolt holes. Drilled some holes in the hub cap, coated the drilled holes with some enamel nail polish, and attached the light to the hub cap with some good stainless hardware and rubber washers to help prevent any water intrusion. The light itself also had a rubber gasket on the back as well.
The whole unit plugs into a long pigtail that runs through the center of the spare tire, down the back of the spare tire carrier and then under the space between the body and the frame where it’s spliced into the rear wire harness.
There is enough slack in the wire that runs down the back of the spare tire carrier to accommodate the opening and closing of the carrier. The wire is also wrapped in a body colored corrugated wire tube to help protect it.
It’s certainly not for everyone, but we have put so much work into this 40 that if this addition helps prevent someone from plowing into the rear, then I think it is definitely worth it and is kinda cool IMO. Here the finished product!
It’s so crazy how much the Fj40 has changed since this photo from 3 years ago! Everything on and around the dash was a disaster and now it’s all back to 1975 specs!!
Thanks! It’s been a long project that can finally see some light at the end of the project tunnel. I’ve been very fortunate to have talented friends and family to help me, from really good new and used parts professionals to knowledgeable mechanics and fabricators.You have done a fantastic job! Congratulations!
