Definitely not a post head gasket problem. If you are noticing the cracks after doing a head gasket then in my opinion the cracks were there when you pulled the head.So it seems the head cracks happen after having the head gasket done? Is that the consensus? And if so, why? Improper torque? Really curious because I've been thinking of having the head gasket done as PM.
My LX450 was on the original head gasket and it was cracked.
Unfortunately it looks like I’m going to be a two time member of the cracked head club. I noticed a burning oil smell on my Land Cruiser last week so checked the obvious spot and sure enough there is an oil path right where the heads crack. I pulled the heat shields and lots of oil buildup on the exhaust manifold. I replaced the valve cover gasket last year so not likely leaking from the gasket. I cleaned it up and plan to check it again this weekend to confirm the cracks. The Land Cruiser is still on the original head gasket.
If it is cracked, and I'm pretty sure it is, I plan to take @Rifleman 's advice and try to fill the crack with some Loctite 270.
I’ve tried to come up with a reason why it is happening but I don’t have any good ideas. My LX450 came to me with cracks and I don’t have any PO history. I installed an Ultragauge as soon I got the truck and it never had a temperature problem. Would rarely get over 200 degrees.
I’ve had the Land Cruiser since 2003 and about 140K miles. Never had a temperature issue with this one either. I have seen temps as high as 217 when loaded down and towing the tent trailer but normal operation is always below 200.
