Antenna Switch Breakout for 1998-2007 Land Cruiser 100 and LX470.
The ASB100 allows you to use the power antenna switch on the dash to control an accessory with momentary power such as a winch solenoid. The ASB100 replaces the stock Auto Antenna Control box and plugs into the factory harness.
The ASB100 contains two 8A DPDT relays, one for the antenna UP button, and one for the antenna DOWN button. When each button is pressed its relay is activated. When the button is released its relay is deactivated.
The ASB100 has 16 terminal block connections for all of the relay terminals as well as vehicle power and ground. You have complete flexibility in wiring to the relays depending on your needs. The terminal blocks accept 16-26 AWG wire.
You can also choose how to power the relay coils. For convenience the relay coils come pre-wired for ACC power, and IGN power is also present on the terminals blocks. For added safety you can also add an additional switch to enable the relays.
The ASB100 is made in the USA, hand-assembled, and tested with care in Oregon. Installation requires only a Philips screwdriver to remove the Glove Box, Liner, and OEM Control box. Not even ½ .
ADDITIONAL INFO:
- See the attached .PDF document for installation instructions and technical details.
- For cost considerations the ASB100 is not fused. It is highly recommended to add inline fuses to any accessory wiring to the terminal blocks.
- The ASB100 replaces the OEM Auto Antenna Control box and does not allow control of your power antenna. If you wish you can change to a manual antenna or leave the power antenna in the raised or lowered position. The Land Cruiser 100 and LX470 have two antennas: A powered mast on the front passenger fender and an antenna printed on the rear passenger vent window. Both of these antennas can be used by the in-dash radio.
COST:
- $129 shipped via USPS Priority mail
- DM for payment & shipping information.
AVAILABILITY:
- 6/2022: In stock
Thanks for looking and please respond with any questions or comments!
ADDITIONAL INFO:
COST:
AVAILABILITY:
- 6/2022: In stock
