I agree with this. I bought a set of 2016 wheels and found that the center caps didn’t fit my 2013 front. I trimmed the mounting tabs on the center caps a little and now they work fine. There is even a line molded into the plastic where you should stop trimming them. The marks could be coincidental, but they worked.The 2016 up wheels will bolt on to a 2015 and older, but the center caps won’t fit in the front.
Thanks, I was having them try to seat the wheels without any center caps as I knew they needed some dremel work. They could not get the fronts to seat over the 2015 hubs. So I am scratching my head about how this actually goes down!I am running 2017 wheels on my 2013. So same wheel setup. The center caps fit the rear fine. For the fronts I needed to remove about a 1/4" of the plastic lip on the cover to get it clip into the wheel. I used a grinder to remove the material.
Until that 1/4" of martial is removed from the inside of the front wheel covers the wheel will not sit flush to the front hubs with the center cap in place.
