I’m checking my carb this weekend and see that choke valve is not fully closed (horizontal) when choke is fully pulled. But, the choke shaft turns fully to the stop and I can cold start with the choke pulled after 4 or so gas pumps. Do I need to adjust? And if so, how? I’ve searched the FSM and see on 2-15 that choke valve should be “fully closed” but then on the carb assembly section (6-53) under choke breaker, there’s a choke valve opening angle of 45*.
I’m attaching picks of my carb with choke fully pulled as well as pushed in all the way.
Thanks,
Thanks,
