I purchased a vehicle that has a pretty well done air bag system on it. It is also pretty hefty. Using semi truck heavy duty airbags with over 26 inches of articulation in the rear and 17+ in the front.
However, the onboard air system is lacking. Here soon I will replace the system and will upgrade it so it can handle the airbags but it still has one problem. I am not sure I like the valves that are being used to control it. Right now I can control each corner independently, which I like, and it inflates just fine (very quickly) but it does not deflate quickly enough. It is terrible.
I don't even know where to begin to look for other valves or other air system devices that may help with this. I plan on building and installing a whole new manifold for it. Just trying to do some research and looking for any advice any of you might have on this.
Thanks!
Thanks!
