For Sale 1997 LX450 Locked and Loaded
Price lowered to $18,250
I am offering for sale my Lexus LX 450. The only reason for selling is that I am considering another project. My family and I have made several trips in this truck including a 3,000+ mile trip from Texas to Oregon (via: New Mexico, Colorado, Wyoming, Montana, Idaho, California, Utah, Nevada). I would not hesitate to drive this thing anywhere.
1997 LX450
190,000 miles (still driving it)
Suspension:
-OME springs
-850J front
-863 rear
-30mm spring spacers on all springs
-OME shocks
-Land Tank caster plates
-Custom rear lower control arms (.33” longer and sleeved with 1.75” .120 wall)
-extended rear sway bar mounts
-front sway bar not installed, but is included
-front and rear adjustable pan hard rods with slee poly bushings
-New Toyota bushings:
-sway bar mounts
-front radius arms
-rear LCAs
-rear UCAs
-Stainless braided brake lines
-This is a very well sorted set up. Everything works flawlessly.
Armor:
-ARB up front
-custom rear bumper with spare tire swing out
-custom built step/sliders
Exterior Accessories:
-10,000 pound smittybuilt winch with synthetic winch line
-rigid LED work light on rear
-rigid LED dually lights on front (need to be rewired)
-hi lift jack on spare tire
-all clear light covers front and rear except for red marker lights and brakes
-LED marker lights
-I believe 7 cree reverse lights (I need to look back to make sure they are 7)
-bottom of truck sprayed with U-pol raptor liner
Running Gear:
-Factory lockers front and rear
-center diff lock switch
-5.29 nitro ring and pinion gear sets
-nitro chromolly birfs (the new high mileage ones)
-DC front drive shaft
-rear drive shaft re-sleeved and balanced with new OEM U-joints
-EMS stainless exhaust from headers back (new cat and muffler)
Wheels and Tires:
-5- 37x12.50x17 BFG KM2 tires (less than 10,000 miles on them)
-5- Hutchison Rock Monster double bead lock wheels (DOT approved)
Interior:
-all new leather on front two rows including door arm rests, head rests and center console
-front seat heaters
-Fat Mat sound deadening throughout entire truck
-dual battery set up with national luna harness and gauge
-Blue sea fuse panel wired and installed in rear quarter panel
-Third row seats included, but not installed
Preventative maintenance and service:
-front axle completely rebuilt with all OEM parts in spring 2013
-rear axle rebuilt with all OEM parts fall 2013
-new front and rear brake pads fall 2013
-new rear rotors fall 2013
-new brushes in alternator
-Full tune up:
-belts
-plugs
-wires
-distributor cap
-rotor
-all fluids changed in engine and diffs before every trips (this is an extra vehicle and doesn’t see 8-10 thousand miles per year)
-it is the original head gasket, but shows no signs of issue (if it ever did I would replace it)
Hit list:
-CEL light comes on and off from time to time. It is an EGR code. Doesn’t cause any issues.
-I would like to recoat the bed liner due to a few chips in it
-front bumper is bent on the passenger side from a winching accident (see pics)
-the same winching accident broke the wires on the rigid LEDs on the bumper
-antenna mast is broken off. I have a new one, but not installed.
I am sure I am forgetting something, so if you have questions please ask. The truck is located near Graham, TX. The price is $19,500.
a few more. I'll clean the engine and undercarriage and get a few more if needed.
I do have a build thread in the 80 tech section. Just search my name. It is not complete because I'm not good at keeping up with it, but it shows a bunch of the stuff I've done to the truck.
Very impressive 450! Like those wheels. Should make someone a great rig.
I would consider a trade for the right 100 series. I'm not sure this is what I want to do, but I would entertain it for the right truck.
Bump for a sweet ass rig! I want those rims!!!
Sent from my iPhone using IH8MUD
Thanks guys. I thought it was sold but it's still available.
I forgot, it also has remote start for those cold mornings.
Also has remote start for those cold days and all LED interior lights.
I am open to offers, but I'm not going to sell it for $9,500. I'm not trying to be disrespectful to the offers, just want to give everyone a heads up. Thanks for looking.
Several PMs for straight on side shots. I'll get them up ASAP. Sorry if I've been slow to respond, been busy.
This rig is the real deal. I have been around it several times. It is clean too! Bump for an honest seller, and an awesome ride! GLWS!!
Daniel
