- Joined
- Jul 12, 2010
- Threads
- 28
- Messages
- 123
- Location
- Rogers/Bentonville AR
- Website
- www.wilder.solutions
Hi, I recently bought a 79 'B' engine Land Cruiser
Long Story:
I flew down to Florida to buy the thing, and it ran great. Started right up and ran smooth with no smoke, it was beautiful.
The odometer said '48850' and it's in kilometers, but it occurs to me that the odometer only goes up to XXXXX, so for all I know it could be 1 48850 or 648850
Anyway, I bought it, I drove it, all good so far. I took it to a mechanic and had him change the oil, grease the fittings, and check the fluids. All good. He said that the hoses, belts, and seals were 30 years old, but all in good shape and should last till I get home.
So, time to drive it home (Dallas, then Bentonville Arkansas).
I got started and made it about 500 miles running 70ish on the freeway, all smooth and comfy, but then I noticed getting off the highway to get gas that it was idling hot; the rpm's didn't drop down like they should. As I went on it became more and more evident, when I let off the gas or put it in neutral it idled fast and was getting rough. Before long there was some white smoke along with it.
When I hit 7 or 800 miles it was pretty bad, so I stopped to do something about it. When I let off the gas it runs fast and rough, and belches out a lot of white smoke. As soon as I push on the gas though it clears right up and runs smooth. I changed the fuel filter and the 4 fuel injectors cause I had all new ones in a box that came with it, but that didn't solve anything.
Now I've driven another 350 miles to a friend's house in Shreveport LA and the problem may be a little worse, but it looks about the same. It's also burned some oil over the last 3-400 miles.
so what can I do? Can I drive it the rest of the way home (another 350 miles)? Should I not? Who'll work on it anyway? Most mechanics I've asked won't touch it and the tractor service places won't either.
Short Story:
Runs smooth on the freeway, when I let of the gas it puts out white smoke.
Idles too fast and rough.
Brand new fuel filter, oil, and injectors, some oil is disappearing.
Conclusions:
I figure it has to be an 'injector pump' or a 'compression issue' although I couldn't tell you what that actually means.
Anything I can look for? Anything I can try? Any suggestions who to take it to?
And lastly:
Can I just drive it home or should I not?
Long Story:
Short Story:
Conclusions:
And lastly:
