I guess the typical old story, was the engine idled down for a couple minutes before shutdown throughout its life?
You should not be able to feel any end play by hand, most have some due to wear.
How much is to much end play or bearing wear, you could use a dial base and indicator and check the FSM specs.
The rebuild kits are way over priced for a couple tiny seals and a bushing which they call a bearing. Although locally I have found no other source for these kits, might find something cheaper out of Austrailia.
Should have a couple of tools such as michrometer to measure shaft wear.
Many people think they should be rebuilt by a turbo shop and not left to a first timer?
Hey Steve, you just missed David and his friend who traveled through Victoria on Sunday in thier jap spec HJ60.
Drop by if your ever in Nanaimo, really dig those JDMs.
Rob
