Good progress over the last few days. Stripped both frames completely down and set them side by side on jack stands.
The first thing I confirmed was that both engine mounts definitely HAVE to be changed. It does look like the FJ62 frame is the best one to do this swap with as it does indeed have the A440 automatic tranny mount in the same position as near as I can tell. I found a PDF of the dimensioned drawing of the frame in the Body Manual (thanks to
www.birfield.com for keeping this link alive). It shows the HJ60 and FJ62 as having identical frames and gives all the body mount dimensions but does not specify engine mounts. (This is page 562
http://picasaweb.google.com/longnow/LCFrameSwap/photo#4977421904966778898.)
I took a ton of measurements of the mounts on the HJ60 frame.
Pics of this start with this one:
http://picasaweb.google.com/longnow/LCFrameSwap/photo#4971845624655904786
I took more measurements than shown in the pics, (mostly with a set of 12" digital calipers to close-by holes and reference points). The main dimensions I paid a lot of attention to were the ones to the tranny crossbar points, as I want the engine to have the correct spacing to the tranny mount. I also made a few dimensioned drawings you can see here:
http://picasaweb.google.com/longnow/LCFrameSwap/photo#4977421756807643154. One thing that occurs to me in all this is that it would not be too hard to make up a set of engine mounts for doing this swap that reference easily on an FJ frame.
Then I took a plasma cutter to the FJ62 engine mounts, cutting them into three parts, to make the welds easy to bend backward and snap off with no damage to the frame. Conversely on the HJ60 frame I took the grinder and plasma cutter to the frame to release the welds, saving the mounts.
A couple pics of this start with this one:
http://picasaweb.google.com/longnow/LCFrameSwap/photo#4971846939359510546
Then I ground down and cleaned up the weld area on the FJ frame, and cleaned up the HJ mounts on a grinder and wirewheel.
With a set of clamps I set up the mounts on the FJ frame visually at first. Then I started repeating my measurements from my drawing, and slowly adjusting the mounts to match. Again the numbers I paid the most attention to were the ones that referenced the transmission crossbar. This all went well, I got a little inconsistency on the passenger side on my forward measurements. It looks like this frame had a little damage in that corner and was straightened at one point which I think accounts for it. It was not out more than about .100" on any measurement which I think the various mounts etc can take up. Well see anyhow.
Then my shop partner (who is by far the better welder) tacked them in place, we then pulled the clamps and re-measured to be sure. Then he finished the welds with the MIG welder.
http://picasaweb.google.com/longnow/LCFrameSwap/photo#4971846640443260946
So now I am going to wire wheel any surface rust on the new frame and paint it all up.
