So... how's the power on the 12H-T? Details please!![]()
A couple of the puzzlers I have right now...
1 - It seems my throttle linkage cable is now too long and has a funny bend in it with the 12ht. Does anyone know if there is a different one for the 12ht vs 2h? Or is it a routing thing?
Could this be a RH/LH issue?? Your 12HT is from a RHD vehicle and your cable is from a LHD.
Good point. Very likely something like that. What I need to find is a shorter cable, I will take some measurements and see if I cant find something that will work.
Okay it looks like I just had the routing wrong on the throttle cable. All is well now with that.
So now I just need to figure out what to hook up to the green and red turbo lights on my tach and all is well. I should have this thing running this weekend if all goes well.
Green is "normal" boost, red is "over" boost. I will try and find the specs for the pressure at which they light up. (after supper)
Do you have the boost switch set? They are a simple set up. 2 wires, 1 for red one for green and it grounds through the mount.
See pic of location in HJ61 engine bay.
Info for Ya.
12HT (Hj61)
136Hp /100Kw/3500rpm
315Nm/1800rpm
1HDT (from HDJ80) - the newer one
167Hp/123Kw/3600rpm
360Nm/1800rpm
