hello, does anyone here has 100 series with 1HD-T engine? i would like to know if you have change the down pipe? it is after the turbo outlet pipe down to the miffler under. around 4feet long.
HDJ100L said:hello, does anyone here has 100 series with 1HD-T engine? i would like to know if you have change the down pipe? it is after the turbo outlet pipe down to the miffler under. around 4feet long.
HDJ100L said:hello,
i am changing it because i bought a new muffler from japan. and i want to have same pipe size(70mm). bigger pipe more power.
