100s with 1HD-T engine......
Philippines
hello, does anyone here has 100 series with 1HD-T engine? i would like to know if you have change the down pipe? it is after the turbo outlet pipe down to the miffler under. around 4feet long.;)
Why would you want to change it.?
Are you doing an engine conversion or is it damaged?
From memory it is different to a non turbo.
hello,
i am changing it because i bought a new muffler from japan. and i want to have same pipe size(70mm). bigger pipe more power.:)
You are saying you have a 100 series with a 1HD-T engine in it??? As far as I Know, the 100 comes with 1HD-FTE and the 105 comes with 1HZ in the diesel Models.
:confused: :confused: :confused:
Michael
