- Thread starter
- #21
Well, that's all they really offer around here. Otherwise, I would have gone with 10W-30. Would I be better off using the Mobil 1 fully synthetic 10W-30 or 10W-40 that I use in my gas/petrol toyota?
This is actually what I use in my Toyota Tacoma with gas engine.
Seems like there would be at least some advantage to using the diesel specified oil. Is that not the case?
Diesel engine oils usually have more detergent to help remove soot/carbon from the oil, and zinc compounds to help lubricate/ reduce wear in bearings.
Oil with 1200ppm ZDDP zinc/phosphorus compounds is recommended for diesels to improve bearing longevity.
Gasoline engine oils will have a lot lower zinc content, or no zinc as zinc clogs catalytic converters.
Thanks for the additional info. That's good to know.
Just getting into a a 3B and know about flat tappet oils from the 2F cam history.
Based on what I see, Mobil 1 Turbo Diesel 5w-40 is the way to go. Good start up weight to quickly build pressure and a nice zddp package. A little pricey oil but you get what you pay for here.
They had the 1 gal on sale for $30 at O'Reilly's and I stocked up enough for a few OCIs.
That is kind of interesting. I don't have a turbo but wonder what the logic is with 32F.The HDJ80 FSM specifically states to never use 5 weight oil in turbo-charged engines above 32 degrees F.
Diesels these days have catalytic converters and diesel particulate filters. So the old anti-wear additives are basically gone and new antiwear additives do the same job but aren't ZDDP.Just reading on "Bob is the Oil Guy" and it looks like the Delvac has been reduced in zddp (zinc) additive. That stinks. Still good oil but the high zinc content was what I have been after.
There is a new consensus for "Mobil 1 Turbo Diesel Truck 1300 ppm Zinc. Mobil 1 V-Twin 1750 ppm Zinc."
I might give those a shot but no idea what viscosity they can be bought at.
OR... maybe just dump in a zinc additive and stay the course otherwise.
I already dump additive in my diesel fuel for lubricity, why not the oil?
Remember when diesel used to lay on the ground forever when it was spilled rather than evaporate like gasoline? That can't be good for a diesel engine, especially an old one.
I promised myself I wouldn't wade into these oil debates but here I am.
The spec for a 1hdt/FT is JASO-DH1 - this is an ancient spec from 30 years ago. Pretty much any oil will be fine. I use whatever diesel mineral oil is on special at the FLAPS near oil change time. I've run Penrite, Gulf Western, Castrol, Nulon, basically everything that's on the shelf here in NZ.
Bottom line is that all modern diesel oils are better than what was around in the early 90s. Buy whatever is on special and change it often.
IMO 3000-5000miles is madness. It's not the 1960's any more. Many vehicles now are north of 30,000km and John Deere are advertising diesel oil with 500 hour oil change intervals.If you’re really concerned about how an oil performs in your engine run it for a change interval and then send a sample off to an oil analysis lab to have it tested. Only about $40 and they give you a full report on all the different metals, elements and other stuff they find and compare it to similar engines.
I use Shell Rotella T4 15w-40 in older diesels (12v and 24v Cummins, 1HD-T, OM617) and Rotella T6 5w-40 in my VW TDI.
Edit: the oil change intervals I run are 3000-5000 miles for the vehicles with T4 (conventional oil), 6000 miles for the tuned and heavily worked TDI, and 10,000 miles for the stock TDI. Oil analyses on these engines show that these intervals are well within the oil's lifespan.
