Expression of interest SUSPENSION STUFF FLEXI COILS
My first thread Ive started myself
Just trying to gauge interest from your side of the globe about sending a shipment of flexi coils to the USA.
Flexi coils are a progressive coils. The spring rate is what ever you need it to be (1 spring suits all). The math has already been done and all you need to decide on is how much lift you want for how much weight you have. The windes in the steel are spaced further apart. It starts off thick gauge and gets thinner, the last few winds are very thin.
This means the more wieght you add the stiffer they become as they compress with the weight. It also means uncompressed they are much longer than a standard coil. Which is perfect for people wanting to run long shocks while the coil spring still remains captured between its mounts and doesnt fall away. The ride is very very good.
- When your unloaded with not much weight, The spring is softer giving a great ride.
- When your loaded with weight, The spring is stiffer but more weight makes the coil more active in bumps. Meaning its the best allround coil. And I dont know how you guys survive without them
. I havent worked out linear spring rates in a long time. Just have to decided if I wanted normal duty flexi coils, or plain flexi coils and what lift height.
Note... The blue coil in the picture is standard, the others are flexi coils.
