I have been paying close attention to all of the 37" tire threads and have confused myself. Hopefully it is just my poor logic and lack of thorough solid axle suspension knowledge that needs straightened out.
It seems that a 50/50 up/down travel suspension works best such as the FOR kit, however I am fairly sure that Nay runs a 2" bump stop spacer. I know this has to reduce the up-travel 2" but does this also reduce the down travel the same amount? So a 3.5" lift without the spacers has a lot of articulation, but doesn't spacing the bump stops limit the travel down to the same as say a 2" lift at 8" of travel vs. the previous 10"?
So now if I take say a 2" lift and throw 37" tires on the truck, space the bump stops down 2", will my total travel be limited to 6"? Wouldn't the best compromise be to utilize as much articulation as possible without the use of bump stops or do larger tires make up for the lack of suspension travel? It just seems like a catch 22 to me and this is why I am confused. Why would I want to go from being able to fully flex out my 285's without rubbing to big tires and less articulation?
. Keep up the arrogant and overconfident banter and see where that takes you though bud
